BeoCenter 9500 -- displays 'Code' in upper right
Try the one-way setup of the remote first then for keying the code - here's the relevant page of the Beolink 5000 manual. Configure it back to two-way mode later, if the Beocenter starts working.
If that doesn't help, I'm out of ideas...
EDIT: the second button from the top is "SHIFT", it's a bit hard to read on the pic.
Check this off the list and thanks for the help.  A B$O store is actually in my city so I took my 9500 on down and with their beo1000 remote, pressing 'radio' 1271  - 3 seconds unplug, 3 seconds plug in and we are back in action.   While entering the 1271, there is no feedback on the display.
The battery that needs to be changed is a CR2450, about $6US.
My 5000 remote did not work for the reset so a 1000 is needed.
later:
doug
Good to hear - thanks for posting the outcome.
You probably won't need to do this again for another 15 years 🙂
