Help
I just bought a Beocenter 7700 and I am having trouble with turn table output. When in the tuner mode both left and right channels work fine. When using the turn table the right channel is close to being completely out (max. volume and you can barely hear it it). I notice when the needle first engages the records it plays for about 1 second then it goes out, same thing happens when the needle comes off the record. Also when you get close to the cartridge with your hand you get alot of feedback through this right channel. I carefully inspected the needle/ cartridge visually it looks fine from what I can see. I tried rotating the cartridge 90 degrees to see if the other channel went out and it did not seem to follow to the left channel. Is there a better test to determine what the problem is? This is my first B&O system and I am stumped
Rich
