Grand master? I've been called a lot of things... but that may be the least fitting, ever! 😂
Sorry for the delay, my offline life was the definition of chaos the last few days.
OK...
Everything is accomplished from the BACK of the BC.
1.) (2) small phillips-head screws just below the TT plane. This will remove a small black trim piece that spans the BC. It will allow the rearward removal of the dust cover/hinge mechanism. Be careful that the cover doesn't spring and possibly crack the hinges.
2.) (2) medium phillips-head screws on either of side of the cage. This will remove the cage.
3.) (1) Captive grey DIN lead from TT to socket Q1 -pull.
4.) Carefully rotate the BC upwards so that you can locate (2) medium flat-head screws. This will release the complete TT assembly. Carefully rotate the rear of the TT assembly up and pull backwards. Rotate the entire assembly ~90D and release a lead that heads back into the BC (caveat: my BC clearly has been "serviced" and it appears there were changes to the wiring at this point -yours may differ slightly). The entire TT assembly is now able to be benched and serviced. I will recuse to others for motor service/lube. There are also quite a few threads on here regarding this. If I am not mistaken this TT is very similar, if not identical, to the 3000.
Notes: This is actually a pretty slick piece w/ the way that the TT assembly is one complete extractable unit.
Hope that helps!
