Beo4 remote to beosound 9000
I think that you might have to press GO or PLAY after the 1 2 7 1, and then unplug the system for a bit.
ill keep you updated on my progress guys, thanks so much
no joy at the moment, its staying in "code" mode,
i did notice as ive tried it with the beo 5000 remote, that the display on the remote says "no contact" no matter what i do. very odd
its staying in "code" mode, for now
When batteries are replaced in the BL5000 it defaults to two-way IR mode. If the two-way functionality in the remote is faulty ( usually due to faulty capacitors) then it will display ‘no contact’.
If you follow the instructions in the BL5000 manual to put it into one-way mode then it should still work to control the BC9500, but you will not be able to carry out advanced programming such as clearing timers.
Thank you I'll look into it,plus I still have the beolink 1000 as a back up remote,thanks again 😀
Happy new year guys
Thanks you for your time and your help, as I'm not having any joy with thr beocenter I'm going to list it on ebay for spares, thanks for the offer to repair the remote also.
Regards hulk
