Kindly advise if component video (RCA) can be connected to SCART-RGB x
thanks
mq
p.s. please compare the bv8-40 with bv-10 40 on a scale os 1-10 x I amconfused whether to buy the bv-8 40 now or waite for the launch of
much awaited bv-10
thanks
mq
much awaited bv-10
thanks
mq
hi mq
I have used two SCART to RCA plug cables on my B&Os in the past - both are composite. The B&O Master Link manual however shows a SCART diagram where composite and component are part of the interface.
The wikipedia article similar shows such a diagram with the addition of S-video -->link
Specifically the text in wikipedia says:
"The signals carried by SCART include both composite and RGB (with composite synchronisation) video, stereo audio input/output and digital signalling. The standard was extended at the end of the 1980s to support the new
thanks
mq
hi mq
