Biometric (fingerprint) door locks?
Alternative company:
here is a door lock project that looks like fun!
colors
Previous post - Funny door lock - works if one isn't red/green color blind.
Other issue with the locks would be power failure at the home. For commercial use, there might be a battery backup, but if the power goes out for a prolonged period of time, you might have use the master crowbar lock bypass system for residential use.
I am thinking of getting a safe with biometrics.
wow it's very expensive for a lock door did you see this website?
http://www.serrures-biometriques.com/
All the systems mentioned are available in many different forms and levels, from gimmick type of residential focused locks/readers to high end commercial (professional) products.
 Some things to consider other that price!
Does your insurance company require/specify deadlocks on doors? Most will not satisfy this without an elaborate expensive setup.
If choosing a code pad, if entering the secured area with another person, a code is easy to see and remember by others. Could be your kids friend. Do you want this. In a commercial application that is able to be audited a code is useless as there is no way of knowing if the code that was allocated to and individual was actually used by this individual.
Just a few things to consider, hope this helps.
