Which MMC to fix and how
I'm sure that Benny will take a good look and report back before he does much with it.  If he says the diamond is shot/well used then you can make an informed decision.  If the diamond is good, then a simple and cheaper rebuild is in order if cost is of prime importance.
If it needs replacing, then Axel is your man and you will have a shibata diamond which you know the condition and amount of use it's had.  For the extra cost and security of mind - as well as quality of vinyl reproduction, I still think I'd lean towards Axel.
Dave.
Also consider that, whatever you decide, this is a one time cost, these cartridges will last forever if treated right.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
One time cost ?
Do not the repaired MMCs get worned out , like any other needles ?
Decision finally made. Having had confirmation that MMC1 - 5 are all the same except the cantilever and stylus I have sent my MMC3 to Axel for a Shibata diamond stylus and aluminium cantilever and have kept the MMC2 which I could have repaired at a later date, retaining the original cantilever and stylus.
I am eagerly awaiting the return of my repaired MMC3 and I'm hoping I'm going to be blown away by it and once again rediscover some of my much loved vinyl.
Thanks for your collective input
Hi Peter,
Like you, I had Axel fit one MMC2  with a sapphire cantilever and the original Pramanik , another with a Shibata - use them in my Beogram 6500 owned from new - can't tell the difference to be honest.
Hi Danny
I contacted Axel a few days ago and he informed me he no longer has the sapphire cantilever option. I believe boron is the alternative.
Drew
