What's beomaster better?
What's better? Beomaster 3000, 3500 or 4500? on the market beomaster 4500 is more expensive than 3000 or 3500, but there is ral difference? I have a beolab 4500. Thanks
Well its between the 3500 and 4500 as you will need powerlinks for Beolab 4000.
The 4500 is the most expensive and what the market wants rather than the 3500 which is all down to the different design with mirror panels on the 4500 mostly.
The 3000 is an upgrade of the 2000 with remote options but no powerlinks but a fine basic sounding reciver.
BeoMaster 3500 and 4500 are technically the same. The difference is that BeoMaster 3500 does not have two-way communication for the remote, no timer function and a different look. Two-way and timer can in most cases be fixed by mounting the software of BeoMaster 4500 in BeoMaster 3500, to make a BeoMaster 3500 look like a BeoMaster 4500 is a bit more work.
