I have at least one LC1 more which is not working (just tried, and it did not work by touch or remote) so I'll see if I can revive that one too. I'll need to order more lithium batteries first...
Ok, I managed to revive two out of three LC1s that I have!
It seems that after the battery has been replaced, the unit will not react until after about half a minute after being connected to mains. I guess it does some sort of reset sequence. After that it will work straight away after plugging in.
The last one had a bit of oxidation in the shielding and the battery was completely dead. It tried to fiddle with it for some time but it didn't start working. It might have some other fault. I did not take this fully apart as I wanted to see first if simply the battery replacement would have done the trick. Needs more work, that will be a job for another day - too tired now!
Interestingly enough, the first of my units was Type 2111 (DK version per the service manual), the two others are 2119 (S, Sweden?). First one uses 1.25A fuse while the two others use 1.0A.
I also replaced the Rifa mains filter capacitor in my SN17 power supply.
