Looks like you're right - what a beautiful machine!
I agree, one of the nicest radio produced by B&O. It had simply no luck being produced in the same year as the famous BM900 came to the mark.
But nevertheless the one of the "must-haves" for every B&O collector.
My exemplar (thanks Leslie) is in everyday usage and even my wife loves it :-)
"the_o_master" is right. Had these units already a year ago but now is the time to put my hands on soon! Let's see if I can make them in the same shape as the one I sold to "the_o_master".
Yes Leslie, it was a good work.
But you have promised also to get a a main power unit for me. I didn't get an offer from you jet ;-)
Oops, so many mails and I forget things as I'm getting older๐
Send me a pm (again)!
Very excited to see the cubes get the Leslie touch.
I'm getting the itch for another cube project - but I must hold off! Must.... finish.... other... projects. ๐ฎ
๐๐
Very happy with the keypad on my latest Beogram - I like to think the switches were originally this sensitive, as there is some original B&O blurb that talks about the sensitivity of these keys being 0.5mm, don't suppose anyone actually remembers do they?
Working on a naughty Niles SI-275 amp. The last, and I mean last, piece of equipment I expected to be poking around inside of!
I believe this is where I say:
"Pictures, or it didn't happen."
Is that the series you can daisy chain amp after amp after amp?
I have pictures but cant post them - switching ISPs and currently don't have internet at home. All of this is coming to you from my cell.
Yes, this can be daisy chained but after a few amps or so you will need a distribution amplifier. The signal inputs and outputs are just paralleled with some resistors in between.
I highly recommend the amp. It's an extremely well designed amp. Having it opened up revealed a double wound toroid and independant left and right power supplies. I measured DC offset earlier and the left was 9mV and the right 10mV. Just brilliant.
I just wish I could figure out the problem!! The thing measures like it's brand new and I can't find a single fault! Baffling.
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
