What Are You Working On Now
There
we go again ...
Hey guys, please do not fight again...
We are all here for the same reason, we love B&O!
Please do not forget this ...
Yes I have read through a lot of threads regarding shimming, both here and other forums , and I understand that there is a divided opinion about this. Although I feel more than apt in handling electronic circuitry, this will be my first speaker job. I know there are a lot of pros and cons, but I have to take my skill into consideration. I belive I will try without the shimming method for this first pair, and trying it for the second pair.
Well said indeed 🙂
I don't want to re-open the debate but I will say this. I have done a number of repairs on new speaker surrounds without shimming in the past so I know first hand it can be done. I've never had a repair go bad so far. However, after using the shims on the last few repairs I will say it provides peace of mind that the surrounds are perfectly in place. On my first pair of RL140's I successfully fixed the woofers without shims but it was a real bear. I used a frequency generator to gently apply some low frequency signals to help locate the center position. I finally got it and the speakers have worked great but on my next set I will certainly use shims. So for a first set of speakers to repair surrounds on, the RL 140's are one of the more difficult I would say...just because of their tight tolerance.
-sonavor
Again thanks for sharing your experiences sonavor. Highly valued! 🙂 Yeah, it is a though decision, but I think with the right amount of patience and gear one can probably pull it off. However at a later stage I will also try with shims 🙂
Brand new this one, I think it is just about right color, also lens and motor cleaned.
Now only problem left, annoying occasional open joint somewhere in powersource... working... not working...
....after an hour or so....
Well now, it's finally working 😁
