I admire your work, Rudy., and your blog page is one of very few pages, I visit regularly.
And thanks for the tip but if I'm not mistaken they are gaskets. They are made to seal, not to provide
friction and transfer torque.
Ethylene is a hydrocarbon. It may encourage absortion of airs moisture (think Butyl - used in speaker foams).
Propylene is also a hydrocarbon, which at room temp prefers to be a gas. It will sneak away given the chance.
Best for closed compartments, I think. As in seals.
In my opinion not the most stabile composition for a component meant to work and flex around in
free air constantly - though admittedly, the Beomaster 6000/4 may not be the most belt-rotating thing
in the B&O back-catalogue. ;-)
Anyway, I prefer the belts to not stretch and losen with age, have as little memory effect as possible and
be made from a chemically stabile material, not becoming brittle with age, not hardening on the outside,
not turn into a gooey sticky mess, retain their friction with wear and contain no softeners so they won't be
prone to attack or interact with other plastics they may come into long-term contact with.
I could use one more tester, - anyone ?
