The motor which controls the volume control has failed.  I tried to dismantle it to see if I could lubricated but the little brass cog on the end of the motor broke up when i tried to remove it.
I was considering replacing the motor with a new motor with gearbox, has anyone else done this?
One other thing, how do you get the panel out that holds the motor?  It seems that there is a hidden screw under the front panel.
