Video doorbell with BLGW and KNX
Kiran wrote:
Where’s mjmedlo?...
I’ve not heard from him in aaaages... Regards
Kiran
Born in NL; I ride ML
Good day good day...
Kiran wrote:
I will be installing the modular door bird system at the gates...
I want the same to happen - trigger to turn on home control on NL tv if active. How does the BLGW recognise if any TV’s are active?... Regards
Kiran
Doesn’t make any difference ... you send the home control to everything ... if no product is live then nothing happens... for every panel that is turned on... you’ll get the DoorBird video feed.
Hi mjmedlo
Not spoke in a long time. I hope you are well...
The above makes sense a little.
I have not installed the door bird system yet.
I will be knocking on your door when I’m having problems lol... 👍🏻👍🏻
Kiran wrote:
Hi mjmedlo
I will be knocking on your door when I’m having problems lol... 👍🏻👍🏻 Regards
Kiran
In this particular case... ring the doorbell
Amazon Ring Video Doorbell is a great way to upgrade your smart home and gain control over who’s at your driveway. Add it to your Loxone, Gira or KNX smart home by integrating a smart assistant platform (Amazon Alexa or Google Home).
If 2N works use that, on every home automation project we have done Doorbird has been ripped out.
It is just not configurable enough and the app is no where near as good as Ring IMHO.
Hi chucky
I am trying to connect the DoorBird camera to my BLGW and I have used the streams you posted above but I have a “Error Loading Camera” message on the webpanel. I have included a picture of what I have entered below, any idea what I am doing wrong?
Huw
Hello,
I'm in the same situation as BeoHut with BLI and KNX -  but have invested in a Dahua Doorbell (VHT2000 xx) which is unstable and cannot integrate to KNX or BLI, so now im considering to replace it with DoorBird.
Quistion. I get it, that you can have the DoorBird to trigger my BLI (and hereby my KNX system too) - but can you also have the BLI to trigger the DoorBird (opposite direction) e.g. to Open the Door via the BLI app?  with my Dahua i can open the door via the iphone app.
/Jens
Try Using this stream
rtsp://USERNAME:PASSWORD@192.168.1.9/mpeg/media.amp
I have IP 192.168.1.9 but you need to take yours
Install VLC it is free so you can check your stream
On the BLI it is easier, it discovers onvif
I use a IIyama touch screen in the hall as soon as someone rings I pick up the screen and fire a Hue plug to start the screen for 2 minutes
 In the living I get the picture on my BS4 / LG77 no idea what I programmed?
Hi all
I am considering a door bird for my front door, not to unlock it as the hardware is not installed mainly just for a doorbell and view when someone knows on the door.
The BLI is in essential mode so does the doorbird support auto find on ONVIF?
I see there is one on eBay https://www.ebay.co.uk/itm/124252498813
Would this thing work standalone and give the announcement on the home control screen when movement is detected ?
Is this able to work standalone?
Sean
