Good day good day...Where’s mjmedlo?... I’ve not heard from him in aaaages... Regards Kiran Born in NL; I ride ML
Video doorbell with BLGW and KNX
Doesn’t make any difference ... you send the home control to everything ... if no product is live then nothing happens... for every panel that is turned on... you’ll get the DoorBird video feed.I will be installing the modular door bird system at the gates... I want the same to happen - trigger to turn on home control on NL tv if active. How does the BLGW recognise if any TV’s are active?... Regards Kiran Born in NL; I ride ML
Hi mjmedlo Not spoke in a long time. I hope you are well...The above makes sense a little.I have not installed the door bird system yet. I will be knocking on your door when I’m having problems lol... 👍🏻👍🏻Doesn’t make any difference ... you send the home control to everything ... if no product is live then nothing happens... for every panel that is turned on... you’ll get the DoorBird video feed.
In this particular case... ring the doorbell 😁Hi mjmedlo Not spoke in a long time. I hope you are well... The above makes sense a little. I have not installed the door bird system yet. I will be knocking on your door when I’m having problems lol... 👍🏻👍🏻 Regards Kiran Born in NL; I ride ML
Amazon Ring Video Doorbell is a great way to upgrade your smart home and gain control over who’s at your driveway. Add it to your Loxone, Gira or KNX smart home by integrating a smart assistant platform (Amazon Alexa or Google Home).
If 2N works use that, on every home automation project we have done Doorbird has been ripped out.
It is just not configurable enough and the app is no where near as good as Ring IMHO.
Hello,
I'm in the same situation as BeoHut with BLI and KNX - but have invested in a Dahua Doorbell (VHT2000 xx) which is unstable and cannot integrate to KNX or BLI, so now im considering to replace it with DoorBird.
Quistion. I get it, that you can have the DoorBird to trigger my BLI (and hereby my KNX system too) - but can you also have the BLI to trigger the DoorBird (opposite direction) e.g. to Open the Door via the BLI app? with my Dahua i can open the door via the iphone app.
/Jens
Try Using this stream
rtsp://USERNAME:PASSWORD@192.168.1.9/mpeg/media.amp
I have IP 192.168.1.9 but you need to take yours
Install VLC it is free so you can check your stream
On the BLI it is easier, it discovers onvif
I use a IIyama touch screen in the hall as soon as someone rings I pick up the screen and fire a Hue plug to start the screen for 2 minutes
In the living I get the picture on my BS4 / LG77 no idea what I programmed?
