Hello all,
I've just received a scratched and dented Beolink 7000 that I bought on eBay as not working and without battery pack (it sadly arrived in really shoddy packing and the plastic cover on the table top charger had fractured and snapped the screw mounts off!).
I also bought a NiCd replacement unit from BeoVIenna as from reading posts it seemed a good place to start was to pop a battery in it! (I've also got one of the lithium memory batteries on its way)
I've soldered the NiCd battery up and when I did so I saw the front panel/screen light up for a fraction of a second but then go dark. If I tap on the mirror plate it does the same thing.
I've placed the remote in the charger but nothing happens (apart from if I tap the mirror plate again).
The battery was reading 5.5V before I soldered it in and the charger is reading 0.08V across the left and middle contacts.
It's an ambitious (risky 😂 ) project as I'm not very experienced with electronics but if anyone can offer any help or advice it would be most welcome!
