Iąve just found in my storage U70 headphone and it looks like new but when I took them into my hands I found that the foam need to replaced due to age (black rubber goes off). Any ideas how to cope with this problem?
Max
Max
Even if you should find one that still carries it, it will fall off at first use.
Not always I still have one with the thin "leather" on it and it stays perfectly.
Even if you should find one that still carries it, it will fall off at first use.Not always I still have one with the thin "leather" on it and it stays perfectly.
I have three or four U70s with the black surface still intact. I touched one a couple of years ago and it flaked off
right away so I will not touch the others. I wouldn't expect them to last in use though.
If you have one still intact and holding on, then fine. It may be the last individual from years of production or the
pads may have been replaced back when they were still available but it's fair to say that you would need
more than a fair share of luck to find such a piece, just as much as you would a fresh and complete set of
replacement earpads and I doubt it will last very long with daily use even if you did.
It may not be impossible but telling a Beoworld member, asking for a solution, to just go and find an intact one
would not be a useful option to the OP.
Intresting, I was just thinking how to recover my U70's. I Guess atmosphere were they have been plays a big role in if they go to flakes or not. I have CX100 with original foams, no sing of rot yet.
I think I'm going to wash old pads clean for a start.
Think I'm gonna do an excersise on those U70 pads as well (yes, my fourth, without the black leather). The white looks pretty uggly....
I agree - if you can find a solution to the problem, I am sure many will be very interested.
Leather tend to go bad if not used, if used frequently, like the U70s, just the grease from your skin will keep the the leather fresh and soft, if left in a box or drawer it will dry out, get stiff and start breaking. And as Oreva points out, the ambient where used or stored.
These are the pnes I photographed for Beocentral - I have boosted the brightness so that you can see the texture of the covering. I confess to never finding the U70s very comfortable and my HD600s outperform them by a huge margin. They do look very good though!
