TX arm not lifting at end
More issues with my TX.  Thanks to all for helping me fix the rotted foam and the broken sensor.
My latest problems are the tone arm not lifting at the end of the record and the entire tone arm/sensor mechanism doesn't always move smoothly.  Sometimes it hesitates or won't move at all when it gets about 3/4 of the way into a record.
This happens on 33rpm.  I don't have a 45 adapter so I can't test those.
Thoughts?
Upon further inspection, I found that the belt (2732045) is very worn and loose.
