Trumpet Stands.............Update, Finally found some, Yea
Hi everyone
There are actually two types of trumpet stands, firstly the type I have,  which consist of a spun aluminium trumpet bottom, very  thin aluminium, with a aluminium stem bolted to it with a pressed steel platform bolted on top which the speaker sits on, pictures at the beovox 4700 page, then there is a later version for the S ? series speaker which the speaker is suspended above the trumpet by a T shaped Steel bracket that bolts into the back of the speaker and makes it look like it's floating almost.
The second type are much more robust and steady than the first type.
Beovox 4700?
I would buy them if they were available and not too expensive - been looking for some for my S60's
Just had a quick search on line for Trumpet Table bases - not sure these look right though
http://www.onlinereality.co.uk/prod/5051/trumpet-series-1-chrome-cafe-table-bases/430mm-high-coffee-table?utm_source=Google+Shopping&utm_medium=referral&utm_campaign=Google+Shopping&gclid=CM3n1Mj2jcECFdTLtAodjg0AVQ
Beovox 4700 ??.............Sorry, my bad, here's the link to the description on the Beovox 3800 page http://www.beoworld.org/prod_details.asp?pid=450 ......................I was certain they had some pictures of them attached to the Beovox 4702/3's but it appears I was wrong.
Here's a link to what the later type look like  /forum/imported-unmapped/leslie-sells; ...................Compliments of Leslie of this fine Forum.
As I said before the others have a pressed steel plate on the top of the stand and you sit your speaker on top of that and screw it to the speaker through a lip on the stand into two holes located in the bottom of the speaker.
when I have time I'll re photograph mine and post them here again.
Blydenstein wrote:
Well, a few months ago I came on here and asked
"Quick question......Where can I get some more information on these Trumpet Stands, I know I have seen a page in the products section, but I can't find it again, does anyone have the link please, or anywhere else I could get some Info ?.
I really want to get some, but putting "Trumpet Stands" in the search box of google doesn't really help much, so searching for any for sale is a bit of a problem."
Anyway, a few days ago I managed to secure these from fleabay, attached to a rather nice set of 3800's..............
And am expecting them to arrive in the next couple of days; Obviously these aren't the same Trumpet Stands as the ones that I believe were made for the later speakers, that the speaker sort of "Hangs" from.
Anyway, as soon as I get them I'm going to get as much info from them as I can, and post it here, as it seems that not much seems to be known about this particular stand other than a Part number that is listed under the 3800 description as "Type 8906007", which is of no use when put into any search engines.
I know it's being a bit of an Anorak, but it's taken 3 years to get some of these.
Mission accomplished.
Cheers Paul
Congratulations for that!
Trumpet stands are really very hard to find, especially a pair in good condition.
Maybe as a note: there were also few other B&O items delivered with similar trumpet stands. I am lucky to own a nice little portable Beovision 601 on the small trumpet stand. I think it was also possible to order few other Beovision models on it. It looks also gorgeous.
Best regards,
Theomaster
