Long time no contribution, so back with my experiences upgrading Beosound 5 / Beomaster 5 to SSD.
Basic idea was to have a Beosound WITH some sort of a midsize screen for visual feedback of chosen radio station.
Needed to have the radio running by the press of the RADIO button on the Beo 4 (WAF).
Beosound 5 was acceptable for looks as well, so I had the luck to get one used with 500 GB and a CD ripper as well (to use it as a player only).
(I DO NOT like the looks of the Beosound Moment)
Read through a lot lot of threads here on Beoworld and ended up with the following procedures:
Hardware:
1. Harddisk (SSD) with Marvel 88SS1074 Chipsset: Western Digital WDS100T2B0A WD Blue 1TB 3D NAND Internal SSD 2.5" SATA (110 €)
2. HDD cage Inateck for 2,5" HDD/SSD, 2,5" to 3,5" internal for 1 SSD/HDD, including brackets, screws and SATA 3 cable (10 €)
3. Hardware Cloner: Inateck Aluminium USB 3.0 SATA dual-Bay USB 3.0 HDD Dockingstation with offline Clone function (FD2102) (40 €)
Cloning done with the press of a button (from bay A to bay B).
Afterwards connect the SSD in Inateck Dockingstation via USB to PC
Windows Mini Tool Partition Wizard Free, to expand the DATA Partition (since new SSD is 1 TB)
Before this you need to move the non allocated space next to the DATA partition..
BTW: gparted on USB Boot Stick did not work.
After putting the SSD in Beomaster 5 started Recovery
First try: please use chkdsk, had to press OK several times.
Second try: Recovery runs through smoothly.
Started the update, after some minutes on the newest version (in November 2019: http://swupdate.bang-olufsen.com.gccdn.net/ftp/BeoMaster5/Mk1/Prod/SWService/BeoMaster5_704011945.exe)
Get the network integration done to copy my music files on DATA.
Important: active SMB1 in Windows 10 (several guides on the Internet how to do this).
Map the SSD DATA partition of the Beomaster 5 \\IP-OF-BM-05\BM-SHARE$\ to B: or any other letter
Username BM-USER and Password (set-up in the Beosound 5 menu)
Copy your collection "drag and drop."
Done!
Now I got a fast running radio with a nice little screen - and the chance to play some of my music collection again (moved on to Deezer/Sonos years ago). To ingegrate with my NL Setup I had to get a ML/NL converter as well. So a bit of an overkill for internet radio but I liked the challenge.
I might integrate a Beogram using a Behringer USB device in the future.
Any questions, please ask.
Ralf
PS: I have the service tool as well but wanted to be able to do without (for me the safer way as well regarding cloning (serial numbers?)).
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
