Hi I would like some advice on installing a subwoofer onto my system. I purchased this back in 84 or 85 and it consists of a Beomaster 3000, Beogram 3000, Beocord 2000, Beogram CDX and 4 redline 45 speakers.
The speakers have all sufferd with the dreade ABR rot and I have managed to fix that with some foam flooring underlay and contact adhesive. However I find the bass sounds a bit lacking and having purchased a samsung TV with soundbar and sub woofer the difference is quite significant. The B & O sound is however, as expected, exceptional in all other aspects and the visual styling I think was, and still is, amazing.
So can I add a subwoofer to this system and if so what type (active or passive) and model would you suggest. As I am now retired and my income is not what it used to be, the lower end of the price bracket would be preferable.
Thanks for any advice.
Ian
