Hello,
My name is Gerald and this is my first post here.
I am planning to implement in our new living room a stereo + surround sound setup next year.
The room has a size of about 4.5 m x 4.5 m, but on one side about 1.5 m is also used as corridor. This means: The effective area remaining for watching films and hearing music.will be 3 m x 4.5 m, where the stereo speakers will be placed on a shorter side.
In this room a 5.1.4 system with Dolby Atmos will fit the best.
As backbone a Denon Heos Multiroom system is already installed driving ceiling speakers in the different rooms (BeoVox 1 and others) which is connected to the home automation system implemented with KNX.Therefore I want to use a Denon or Marantz AV Receiver to add then the stereo pair as zone in the multiroom audio system.
As stereo pair (front right / front left) I own already a pair of Beolab 9, which I really like.
As rear speakers I am thinking about BeoLab 8000 or BeoLab 6000, but I tend more to Beolab 8000.They should be mounted to the wall. I know, this is very critical, because the speakers are quite near to the listeners ears ... maybe a pair of dipol speakers would fit better.
As center speaker I would like to use a BeoLab 10 and integrate it directly in the low board at the screen.
Regarding the subwwofer it depends, if it should be visible or not (WAF). If it should be visible, I tend to BeoLab 11. Alternatively I would use something from Klipsch and mount it directly invisiible in the low board at the screen.
As effect speakers I want use BeoVox2-1 powered over the inbuilt amplifier of the AVR.
What do you think about that combination? Where would you improve or use other speakers?
You can answer me in german or english.
Danke und Schöne Grüße / Thank you and best regards
Gerald
