Spotify playlist issues on BeoSound 5
I have bougt an Auralic Aries instead. This cost alot more but I EVER had so good sound in my Beolab5. It is far superior verses all beosound products (Bs5 and Bs9000 with digital feed).
In the latest B&O idea catalogue they recommend Auralic Aries with Beolab 90.
best Regards
martin
So, they came over and the 'secret' solution is to download the latest version of the spotify for windows app that is supported on XP, sign in and you can control the music through the app on phone, tablet etc...
No wifi dropouts and other issues?
My beomaster isn't on wifi. And the way this works is that the app on the beomaster streams music itself, so why would there be drops?
Sorry,i was responding to martin post
Is the installation something you can do by yourself? Do you know if this will be an official installation with support/help on B&O website.
Best Regards, Ingvar
Does or does someone have the possibility to create a manual with eventual with screen printing?
I am using this option.
Only downside is that if you select A.AUX to play Spotify connect, then Spotify will continue to play even though you shift source to Radio.
Would have been great if the Spotify App would stop playing automatically if A.AUX is not the source.
Hi Konig, no dropout and really no other software issue. Auarlic is really fast with new SW when a bug occur.
best Regards
Hi Beolion, what version of SpotifyApp are you using on the Beomaster XP ?
Peter
