Spotify is coming......
Hi MARKSFS,
thanks a lot!
That means: no search function - (and therefore of no use for me)!
Greetings MM
A.MEM? Thanks, then I just add this button on the Beo6 and re-name it.
Roger
You can choose different options for your remote under MODE --> SETTINGS --> ROLES :)
If you start using Spotify on your computer when it's running on the Beosound5, then the "laser-light" turns red until you press GO again.
No search function....
Unbelievable!
How should they?
That would be even more fiddling around with the wheel!
Imagine: searching for R-O-L-L-I-N-G S-T-O-N-E-S-G-E-T-A-Y-A-Y-A-Y-S-O-U-T on that device 😜
Grrr! Millemissen
All radio stations are back again, guess it was just about updating the list with covers.
Double post
Millemissen wrote:
How should they?
Grrr! Millemissen
Yeah that's right
we need a new audiosystem....b&o hurry up!
Or a ipad app just like creation5
