Spotify is stll running on my BS5, also with new playlists....
Stefan
Stefan
I have a Chromecast Audio connected to the UCA222. I do also have Spotify Connect installed. Both works fine for me. A.AUX is used to activate either of them, however, if music is played on the installed Connect, the Connect music will continue if you switch to ie Radio (double input signals) unless you stop the Connect music first. That is not the case when using the Chromecast.So I had a look at the Behringer UCA222 (about $60 so not too bad). But I don't understand how you connect, say a Chromecast Audio to it... there appears to only be RCA audio inputs on the UCA222, so do I then need to use a headphone to RCA converter to attach a Chromecast Audio to the Behringer UCA222? Has anyone setup up a workable Spotify Connect solution directly to BeoMaster 5? Keen to hear some specifics. Many thanks in advance.
What do you mean by " new playlists"?Spotify is stll running on my BS5, also with new playlists.... Stefan
I created two new playlists last weekend with John Mayer songs - btw he`s in Herning, Danmark on Friday and I`ll be there too ! (somebody else?) - on my ipad, and they appear also on my BS5...
Stefan
The search function on mine is now working again.
I posted an answer to this with a link for the appropriate cable after you asked your question yesterday.Thanks Beolion! A few questions... How do you connect the Chromecast Audio to the
Thanks Beolion!How do you connect the Chromecast Audio to the UCA222?: By using a 3.5mm MALE TO 2 RCA MALE AUDIO CABLE (check ebay)
When using Chromecast do you get any cover art on the BS5 or just the A.AUX input text? Yes, that is why I really like the BS5 player where you get the covers.
While Spotify is now working, I'm finding that N.Radio stations are no longer working. This is so frustrating. Is anyone else finding N.Radio stations to be unavailable?
