Spotify connect player for BS5
My dealer advised today that B&O have confirmed that Spotify will not be available on BS5 from May.
Maybe you should untic auto update
Peter
What is your current software? Mine is 7.04.01.1945 - firmware 1.38a
Peter
Peter
Thanks. I'll check when I'm home this weekend.
Auto update disabled 😛
So I had a look at the Behringer UCA222 (about $60 so not too bad).  But I don't understand how you connect, say a Chromecast Audio to it... there appears to only be RCA audio inputs on the UCA222, so do I then need to use a headphone to RCA converter to attach a Chromecast Audio to the Behringer UCA222?
Has anyone setup up a workable Spotify Connect solution directly to BeoMaster 5?  Keen to hear some specifics.
Many thanks in advance.
I asked the same question of Steve at Sounds Heavenly.  I am sure he wont mind me sharing his reply and links.
"Thanks for your enquiry, first you need the USB adapter to connect to the Beomaster 5:-
link
This cable will connect the Chromecast Audio to the USB adapter above (a 1m Chromecast cable can be supplied free of charge with the USB adapter on request - please ask for this when you order the USB adapter):-
link"
Peter
Done that now.
@Duels- is your system back up and running?
Peter
Peter
Yes it is other than playlists.
