Great, it works! I think B&O should make this information part of its user guides - the spotify app on the BM 5 is a real drag without the "connect"-functionality, I was close to returning my center to the shop to have it sold, quite happy with it again :-) Thanks, Beomotion
Spotify connect player for BS5
I tried to follow your suggestion but when I try to connect to google to download Crome, internet explorer tells me it can't connect to the internet (despite I know it is connected to the internet)??
Any suggestions, hints or tips?
BR
Please se ignore this post. I managed to install it through a USB stick and it works well.
BR
BR
BR
BR
BR
I am dealing with this right now... the B&O rep came to my house and confirmed that B&O will not update their support to the Spotify app and admitted about all the bugs they have. For example, Spotify Playlists no longer work on the Beosound5.
I tried your approach but unfortunately, my BeoMaster isn't connecting to BeoConnect - need to debug that one first
No need for 'debugging' there.
The BeoConnect is not supported in newer OS.
Map the BM5 drive on your PC/Mac instead and drag and drop your files from there.
We inform you hereby that the Spotify functionality in the near future will be removed from the BeoSound 5.
This change does not only affect Bang & Olufsen products, but also includes other brands that use the Spotify implementations. In addition, Spotify will also send a message to customers who use products to which the amendment refers.
