This must have been the spotify app you installed at some point that came alive somehow. I'm using the same solution.
No way this is the old integration working again. That one will never come back.
Yes, I agree on that one.
I have Spotify installed manually on the system, and the system has the default name BEOMASTER5 using Spotify Connect.
However, we know that Spotify have turned off the API's that B&O "natively" used to connect to Spotify, but since the installed Spotify on the BM5 Windows XP system is working, I wonder what API the standard Spotify software is using and why B&O cannot use this.
