Speaker wires/ B&O to non B&O amp.
Hi there,
Just bought this little amp off of Monoprice.com to play with. (love the warmth of tubes)  However, as you'd imagine, the speaker connection are designed for bare wire or other terminals but not the B&O DiN system.
Anyone know if they make speaker wires that will work with both or if there is a solution?
I currently have a BS4 and the Beolab 4000 speakers.  If you click on the image below, you can see the speaker connections for reference.
Thanks!
The Beolab 4000 speakers are self amplified.  I am not aware of a way to bypass the am and use your tube amp.  Sorry.  You will need to find a set of speakers that do not have the amplifier built in.
