Hi!
I just got a broken Beolink 7000 together with the charger for a good price. As the most common problems with these ones are the batteries, I bought five 1.2v AA NimH rechargable batteries and put them together creating a battery pack at 6v.
I connected the new battery pack and put the remote on the charger for some hours. I now got +6v and ground on the incoming lines of the circuit board. But it's still dead! Are there any fuses or other things that might be broken? I've checked the solderings and most of them looks ok.
Thanks!
EDIT - Problem Solved:
Thanks for all the help, the problem is now solved and my Beolink 7000 works great! The fuse had blown and there were a bad solderings and a loose connection between the boards. It now works great together with my Beosystem Av 9000. Anyway, I am very happy I bought this masterpiece for 2000 swedish crowns!
As a sign of my gratitude, here is some pictures of it in action! =)
