Smoking Beomaster 5 - possible capacitor
hi guys , I’m hoping someone can help with an issue I just experienced with my Beomaster 5. I hadn’t used it for a while and plugged it in. After about 30 seconds it started making a terrible noise and I quickly turned it off at the power point. It started smoking and smelling really bad . I opened it up and found something on the mother board had failed . I think it may have been a fuse but not sure. I’m not really sure watt to do but thought someone might be able to help me.
Do you have a photo of the failed component?
Also, do you know how to solder replacement components if we can determine the correct replacement part?
Yes I do have a photo and I think I could solder if we found the failed component.
Hi Laseralex
thank you for your reply. Did you see the photo I posted of the item that exploded?
No, I don't see any photos in any of your posts.
May be many things...you can send me PM with photo.
How do I send a photo ?
