I had several Morris Minors in my youth.
The front suspension wheel supports consist of vertical steel castings (a long kingpin) with a threaded top. A sort of brass or bronze trunnion fits onto the threaded part allowing the wheels to pivot.
This type of suspension is notorious for failure but not quite as you might expect. Even with regular greasing, microscopic fragments of steel get embedded in the brass and then work abrasively on the threaded steel casting. On failure, the brass trunnion appears to be in perfect condition, but the steel threads on the top of the kingpin itself are almost completely worn away. Trunnion pops off, wheel collapses..... ! It wasn't just Morris Minors. 40 years ago cars at the roadside with front wheels at strange angles were a common sight!
Graham
