Setting up a ps3 to a Beovision 8 - 32
i just purchased a Beovision 8 - 32, and I am having a hard time connecting my PS3 through a HDMI connection. I am not sure how I should go about setting it up in the connections menu.
The trick is to Connect both hdmi and standard connection simultaneously . Set hdmi to dvd and standard cables To say (v aux) then switch the settings for each at Beovision Menu be sure the standard def connection is working.
Then switch visible standard ps3 connection from standard to hdmi ..You may need to do a display setup and audio setup through ps3 (second to last menu item left ) scroll down to display settings ...may also need to adjust white balance and another setting for hdmi there. Switch to hdmi input ( in my example DVD) on the Beovision
That should make it work.
Just went though this setting up ps3 also as media server from computer.
Hope this helps
