Decided on a new post to better explain.
Im trying to set the trim pots as instructed with no source and no speaker load. The amp will only power on for 3-4 seconds and only in the "link" position. Both amps act this way and its not enough time to set either pot. Because they both do this, i suspect its normal. They are probably looking for a source signal and turn off after not finding one.
How do i get the amps to power up and stay on ?
