SC60 Cabinet
Hey mate,
Sorry for bumping your thread although great work! I have came across the same cabinet but its missing the dividers in the middle as well as all the screws. Do you know the exact screw type to attach the boards to the legs? and do you know if there are reproduction dividers (not sure what material they are)>
Cheers!
I don't know what type of screws they are other than the B&O service manual identifies them as B&O part number 2084006.  I can remove one and photograph it later.
The dividers are steel.
-sonavor
That would be great thankyou, not sure id have much luck trying to get the exact bang olufsen screws.
Hey mate,
any luck getting the picture of the screw? Not had any luck getting spares myself so will just try and mimic the original as best i can.
Cheers!
Here you go
They are melamine screws and look like they are very similar to these.
Confirmat screw...
