When I put a record on the platter some of the records scrape the record player because I think the platter is a little low. Is there a way to readjust this so the platter is above the edge of the player? I noticed that the Suspension is very sensitive. I believe that if adjusted only a 1/6th of an inch up would do it.
If you look at the picture I provided you will see the platter is almost flush with the turntable making some records scrape the turntable. I believe there is a way to adjust this so it is raised just a hair.
