tournedos wrote:
hemenex wrote:
There must have been a retrofit kit to replace the ABR with those tube plates. I think Leslie even had the number...
Yes there was. I believe that from all the cures to the broken ABRs, that would be easiest and cheapest to remanufacture. I guess all you would need is the location of the reflex hole and the lenght & cross-sectional area of the tube, and it would be close enough to sound reasonable?
Easy and cheap aren't necessarily required. What I don't want to do is spend the time, energy, and money to fix a product that isn't worth fixing. So far, I haven't come across anything to lead me to believe the RL60 was a poor product. On the contrary - most folks that fixed them and reported back on their sound were quite pleased.
So the question becomes, which fix? It seems the options include:
1) Find a B&O produced retrofit kit somewhere (bass reflex conversion)
2) Produce a facsimile of the retrofit kit (bass reflex conversion)
3) Get a repaired set of ABRs from Martin if he indeed finds some in his dungeon
4) Source a set of ABRs here in the states
5) Produce a facsimile of the ABRs using materials and equipment where I work
6) Try Mike Cason's retrofit of two 5.25" passive radiators per cabinet (the PRs are still available at Madisound for about $10 each)
I'm not as big on "keeping things original" as some others are, so I'm game to experiment. Perhaps in the end I'll try multiple fixes.
