Hey guys,
After owning a white 6500 system minus the turntable for many years, I came across a mint white beogram 5500 in the original box for cheap. Of course there is the RIAA issue. I already have an external RIAA amp I built with din connections to allow me to use my non-RIAA turntables with my 6500 stacking systems. So I could simply use this to connect the 5500 to the rest of the 6500 system.
Alternatively, I have a 6500 beogram parts unit in mechanically junk condition but with fine electronics. I'm considering trying to replace the 5500 board inside with the 6500 board from the parts unit, so the RIAA is then inside the 5500 turntable. Going by the service manual it looks like in addition to transplanting the RIAA board I'd also have to cut some traces to bypass the muting circuit that's in the non-RIAA turntables. Therefore I was considering just transplanting the RIAA together with the 6500 main-board.
I will admit that with the turntables and service manually I have the ability to determine this myself by studying the manual more and opening both turntables. I figured I'd try to save myself some time by first seeing if anyone else has transplanted 6500 or 7000 internals into a 5500.
Thanks!
Austin
