Just purchased a second hand Beocenter 9300 and Penta speakers, sounds wonderful and in almost mint condition.🙂
I had a demo at the house I purchased it from and it ran fine for about 2 hours at home.
When I went to put in a new CD the opening door jammed, I could move it with my finger (gently) and it closed itself OK.
I assume it wants the runners cleaning or a new door opening belt fitting. I can use it but would like to sort it out before some permanent damage takes place.
I see a number of posts on "the door opening problem" topic but not seen one that says what you actually do.
I am an old computer/electronic engineer so do have some skills in this area.
Question - How do I get to clean the runners and replace the drive belt (if required)?
Also (I live in the UK), where do I get the drive belt for the CD & tape cassette drive?
Thanks - a B&O newby.
