1. They listen for the Atlona commands so you can use theStandard Atlona PUC
2. No problems no problems at all.
3. Just to be careful when setting up the product integration settings in the new TVs take it stage by stage and you will have no problems. Why not call Martyn @ Pulse eight (the MD) he is just fab, he will tell you all you need to know and more.
Thanks StUrrock - info much appreciated.
Cheers,
Martin.
