Hi there, yes indeed the matrix can sense beo remote commands and then send them to the appropriate device attached to the Matrix - through the necessary PUC codes.. Is there anything else you would like to know?
Thanks,
Alex
Thanks,
Alex
I've never used an Altona so don't know exactly but it works as you'd expect - seamless distribution of video sources with full ir control.
Does this matrix so source switching?On the matrix itself?I.e. Source 4 is aTV and source1 is cable Can this matrix switch between the boxes AT THE MATRIX.Hi there, yes indeed the matrix can sense beo remote commands and then send them to the appropriate device attached to the Matrix - through the necessary PUC codes.. Is there anything else you would like to know? Thanks, Alex
Thanks,
Alex
Thanks for your reply, Alex,
so I`d like to know more details about your setup and the way you use the neo matrix, if you don`t mind...
Which beovisiond do you use in your setup?
Is it a Masterlink- or Netlink setup?
When you control your 3rd party devices via the neo, is it via the Beovisions or via the neo IR receivers?
Do you need the Beo matrix activation key?
Which puc do you use for the matrix, as mjmedio said there is no pulse eight puc in the Beo database.
Do you control the devices by Beo`s source butoons like TV, DVD, V.MEM...? You said, the four sources connected to the neo are listed as Matrix 1,2,3,4. (I assume you have the 4/4 HDbaseTmatrix). What is displayed on the Beovisions, when you select a source?
Sorry, a lot of questions... and thank you again for the kind help!🙂
Stefan
Hi Stefan,
Just to let you know, in December 2015, Struer decided they would make the HDMI Matrix Feature activation keys available free of charge. You'll just need to ask your dealer and provide them with the model and serial number of your BV.
I'm also interested in further information on how the Neo Matrix works with a BV.
Martin.
duplicate deleted
Martin, thanks for that information - it`s new to me.
Maybe there are also some members (dealers?), who are able to provide some info, drawings, installation guide, concerning the neo matrix.
StÜrrock already told us in october last year about Pulse Eight.
http://archivedforum2.beoworld.org/forums/p/16884/147323.aspx#147323
Stefan
