PUC and Apple TV 4K
Where to place the PUC on the new ATV 4K? Are there any good suggestions?
I placed mine exactly where i placed it on the ATV4 and it works
When you turn it on you will see the little light on the right hand side, so over that :-)
Anyone who can guide me on how to pair my Beo remote One with the Apple TV 4k ? it worked with ATV3 - I just switched to ATV4K and now i cant use my beo remote for my new ATV :( please help
I did the same but from ATV 2. gen. I just used the same entrance on the Avant and change the PUC protocol to ATV 4. gen. And it worked...
Hej Jan,
kan du hjælpe mig med hvordan jeg gør dette ? jeg fik B&O til at sætte det hele op første gang til - så jeg ved ikke hvordan jeg ændrer PUC koder osv :)
andersenpost wrote:
Hej Jan,
Which tv do you have?
If a newer one, you can download the new/the ATV4 codes and use these instead - see User Guide for howto.
if an older model, your dealer will have to upload new PUC codes to it.
But honestly, I would not spend that money - the old/the ATV3 codes works, but with some limitations for the ATV4 as well.
Just place the ir-emitter on the new ATV box (....and the HDMI cable).
Jf. svaret nedenfor. Via Avant'ens insdtillinger kan man hente ATV4 settings og efterfølgende knytte den til den HDMI-adgang, som ATV'et hænger på.
Hi my tv is beovision 14 55".
Fint - du kan så bare hente koderne selv - følg opskriften ovenfor hhv i tv'ets brugervejledning på side 88/89.
Trying to get this to work on my brand new Beovision Eclipse. Got it connected to PUC 1A and HDMI A. The PUC is set on Apple TV 4th Gen. But cant seem to get it to work. Got an Beoremote One BT (the one without Netflix).
Anyone?
