I have four B&O Light Controller LC2 units in my home. Two of them works perfectly fine, but the other ones can't be operated manually and works only with the remote. Since they are placed on lamps hanging in the ceiling, it's no big problem, but I still want the manual function to work so I can program them for multiple LC2:s in one room and how they shall react to power failures and things like that. And in order to do so I need the manual function to work, becaus when programming the LC2 units you need to hold on the bulb while programming it with the remote. When i try to dim them or turn them off manually by tuching the bulb on the front, nothing happens.
Is this a common problem on the LC2 units and is it possible to fix it?
