Problemen Playmaker en synology ds412+
I used 'dsaudio' a couple of times - my NAS is also a Synology.
And never again. Use PlugPlayer, 8Player, Creation5, if you are a iOS-user!
N.B. I did not understand all, that was written above, but these are my 2 cents!
Greetings Millemissen
And how do you gain access to the dsaudio/synology WITHOUT an iOS-device?
And what do you mean by "autonomously"?
Hi Leufje,
When you connect to audio station on your synology via a web browser (via a computer, not an iDevice), are you able to see "Playmaker" on the device list (by default, the item is "my computer". And there is even a "multiple airplay devices" on the list... If it doesn't appear, then the DS412+ (I have the same NAS) doesn't "see" the playmaker...
