Problem to set option 6 Beosound overture
Hi
I have a Beosound Overture that i want to set to option6, but it dosent to work. If i set it to option 1, 2, 3, or 4, I get a respons from the red led (it blink). If i try to set option 5 or 6 nothing is happening. Does the overture support option 5 and 6 ? If it is something wrong, i would all options to fail.
Regards
Tom
Both worked on mine.  According to the setup guide it supports options 0,1,2,5,6
I suppose your ouverture is too old...
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
As far as I remember, only the latest sw supports A.OPT 5/6, earlier ones just work with A.OPT 0 - 1 -2.
Maybe an update will help?
A.OPT 3 doesn`t exist, and A.OPT 4 (link option) is not supported.
Stefan
