Privat survey of Beolab 5000 - Beomaster 5000 producs
Beolab 5000 Series 09 number 84134 & beomaster 5000 Series 08 number 52591
Hope this is useful Frede
Beolab 5000
Type 5303
Series 07
serial 33669
Hi Frede,
I know that it is very old thread but:
My Beolab is: type 5303, SN: 57513 and serie 10
My Beomaster is: type 2005, SN: 15569 and serie 01
Marcin.
Thank you very much, Marcin.
I got your mail also and will reply to day.
Frede
I got it
Thanks !!
Hi
Still an old tread, but I just received my Beolab 5000 from Denmark.
It was very rusty, but I think I can get it going again. The aluminum was nice, except the volume-writing has been partially worn off from the slider.
Beolab 5000
Serial no 84663 (yes, outside the mentioned range)
Serie 09
Best regards,
Frank from Norway
Congratulation with your Beolab 5000.
Thank you for sharing the Serial no. - right now I can count 542 of serie 09 which I think means B&O have produced this serie of 1000 pcs.
Be careful if your Beolab is rusty, look for corrosion all over the Beolab and clean as mush as possible and specially attenasion to the input and output connections.
The panels - I can supply new panels with full text if you wish. Send an email.
Thank you, it is so good to know that support is out there :)
Its very impressive that you have counted 542 09 series!
I overpaied for the unit, so have to dismantle everything and give it a go with sanding and painting myself. It's all in the preparations. If the result is not 100% I will get back to you on email.
New Beolab 5000 arrived from UK. Nice condition.
Going to change the main cap and filter caps, then check how it looks. I had 60V main voltage and some 30V centre-voltage when I did a quick check today.
Beolab 5000
Serial 33320
Serie 07
Great news then.
Photos or it didn’t happen 😎
