Plastic pre-set tuner cover for the old Beomaster 3000/4000
What a cracking job!
Excellent work geoff!
Geoff,
That's a real nice job.
You're a man after my own heart - if the part doesn't exist, make it.
This is a keeper, for when I have one of these in for restoration - I will be copying you!
Menahem
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
Can I ask what you used for cutting the case?
Hi
After scribing the case in the appropriate places, I just used a mini hacksaw with a sharp fine blade to make the preliminary rough cuts.  Provided that the case is held and supported securely, it doesn't usually crack or split.  Thereafter, I use the Dremel router table to cut the various sections to size and finally a fine file for the smaller, more fiddly bits.
Hope that helps
Regards
Geoff
Great work there Geoff. You would never know the difference.πŸ˜•
CraigπŸ™‚
Awesome - I love these threads.πŸ™‚
Chris.
It sure does!  Looks as good as the original!
