What a cracking job!
Plastic pre-set tuner cover for the old Beomaster 3000/4000
Excellent work geoff!
Geoff,
That's a real nice job.
You're a man after my own heart - if the part doesn't exist, make it.
This is a keeper, for when I have one of these in for restoration - I will be copying you!
Menahem
Can I ask what you used for cutting the case?
Hi
After scribing the case in the appropriate places, I just used a mini hacksaw with a sharp fine blade to make the preliminary rough cuts. Provided that the case is held and supported securely, it doesn't usually crack or split. Thereafter, I use the Dremel router table to cut the various sections to size and finally a fine file for the smaller, more fiddly bits.
Hope that helps
Regards
Geoff
Great work there Geoff. You would never know the difference.π
Craigπ
Awesome - I love these threads.π
Chris.
It sure does! Looks as good as the original!
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
