Hi Guys,
Trying to see if I can get my Penta amps* working, without being too invasive. I like to think less is more and reading some of the threads here I do not want to jump in at the deep end and try replacing a bunch of components, just to find the problem is still there.
The was getting really hot after a short amount of play time. An EE at work told me it could be the No-load current and I see in the service manual how to make sure that is set correctly. Here is what happens when I try to do that -
Amp is completely cold; has not been on for weeks; nothing is connected to the inputs; it is set to Auto. I plug it in; the light is green. Placing the Voltmeter across 1R103 and 1R104 I start to try and get 30mV, but the mV continues to slowly rise... ...Green light turns red. Same every time I try. Am I doing it wrong, or is it time to start replacing components?
I have tried to find a similar thread, but no luck. Thanks for any advice you can offer.
*Two came with the speakers. One seams to work OK, the other had the input area pushed up in to the cavity snapping the PCB! (Does that happen often?). Bought another second hand and this is the one that is having issues.
