Penta - replacement part for spring press switch
Does anyone know if there is a replacement part available from somewhere other than B&O? I'll try them as a last resort but was hoping someone may have found another source. This is the spring press switch behind the control panel face on the amp at the base. It allows you to press the panel in, then press it out again. Currently mine just springs back out each time without locking away.
Any help is appreciated.
I have exactly the same need! I've not found a suitable replacement either as yet, so if you do please drop me a line. (I only need 1)
Thanks!
Beofan for many years with a penchant for 1990s audio systems.
They were not very expensive from B&O when I last bought some. Worth an enquiry?
I have the same need and recently enquired at my local B&O dealer, but he wasn't very helpful. If you find a dealer who still sells this part, please let us know.
Well, I inquired just out of curiosity with the local B&O workshop. I was surprised that they can order them at the reasonable cost of $6 each. I ordered 2. :)
Should be here within the week!
I'll post again once I have them to advise if this worked out OK. If you have trouble I can probably order more and have them posted to you directly. You can pay me via paypal.
Let's see if mine arrive first :)
Regards
Brian wrote:
I have the same need and recently enquired at my local B&O dealer, but he wasn't very helpful....
Called my dealer today and ordered two parts. Probably should have just called in the first place rather than trying to rely on email. 😕
Parts arrived within the week. If you can't find a dealer who will order these for you I could help but it would seem they are readily available and in stock.
Let me know if you need an order placing. :)
Price?
leosgonewild wrote:
Price?
Already stated earlier at 6$ each.
Dave.
Ahh, now I saw it. What is the part#? Have to order some other spare parts, so might as well order the spring at the same time.
